Inseego T2000
Verizon Wireless Home Phone T2000
Cellular External Antenna Port
Verizon Wireless Home Phone T2000 includes an antenna port to attach external cellular antennas. See below for different options for high gain and high performance indoor and outdoor antennas to improve the signal strength and indoor coverage.
Cellular Replacement Antenna
Select Replacement Cellular Antenna Inseego T2000
Find Replacement Antenna
Cellular External Antenna Kit
See below for the most popular LTE antenna kits to boost the signal of your Verizon Wireless Home Phone T2000. These kits include cables, lightning protection, and all required pigtails/ adapters. If none of these pre-configured kits works for you, see below wizard to configure custom kit.
Outdoor Directional Yagi Antenna Kits (RECOMMENDED) | with 20 ft Cable | with 50 ft Cable |
12 dBi Directional Yagi Antenna kit for 698-2700 MHz operation. Slightly larger than Panel (dimensions: 35" x 9" x 2") but higher gain.
Also available with 100 ft cable RFWY12-T2000-100 or see below for custom configuration |
Outdoor Directional Panel Antennas Kits | with 20 ft Cable | with 50 ft Cable |
10 dBi Directional Panel Antenna kit for 698-2700 MHz operation. More compact than Yagi (dimensions: 26" x 13" x 5") but lower gain.
Also available with 100 ft cable RFWP10-T2000-100 or see below for custom configuration |
Outdoor Omnidirection Antenna Kits | with 20 ft Cable | with 50 ft Cable |
9 dBi Omni-directional Antenna kit for 698-2700 MHz operation. ONLY recommended if have no dominant signal from specific direction.
Also available with 100 ft cable RFW0M9-T2000-100 or see below for custom configuration |
For cellular signal improvement, use our tool selector below to Configure Custom External Cellular Antenna Kit:
Configure Antenna Kit
Cellular Antenna Port Pigtail and Connectors
T2000 has 1 antenna port. (NOTE: A custom pigtail is defined for this device.)
Consider these common pigtails for your device:
RFWCAB58SMMNF001 1 ft SMA-Male (SMA Plug) to N-Female (N Jack) Cable |
RFWCAB58RPSMNF001 RP-SMA-Male (RP SMA Plug) to N-Female (N Jack) Pigtail (1ft) |
RFWCAB58TNMNF001 1 ft RG-58 Cable with TNC Male to N-Female Connectors |
Consider common adapters below to connect pigtail or device port to different cable options:
RFWADPNFFMF N-Female (Jack) / FME-Female (Jack) Coax Adapter |
RFWADPNFRPSM N-Female to RPSMA-Male Coaxial Adapter |
RFWADPRPSMSMF RP-SMA Male to SMA-Female Adapter |
Related Cellular Signal Booster Kits
- Find other signal booster kits for Inseego devices.
- Find other signal booster kits for Verizon devices.
. . . search other signal booster kits in the Device Antenna Kits category.
Select custom cables or connectors:
Cable Assemblies |
